B-series A/C Compressors
Old Jul 30, 2002 | 03:37 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default B-series A/C Compressors
Are they all the same? Can I mount a b16 a/c compressor onto a b20 motor?
Old Jul 30, 2002 | 03:59 PM
hurleyburley's Avatar
Default Re: B-series A/C Compressors (GapxGuy)
Check the Hasport web site. They sell an adapter for these motors to mount D series A/C compressors. If all of the adapters are the same... you can draw your own conclusion from there. You could run into problems with the pipes that bolt onto the compressor, depending on your existing set up. Hope it helps.
Old Jul 31, 2002 | 10:52 AM
krazy's Avatar
u should be able to mount it. since all b series blocks are basically the same. u need the AC mount to be the rightone though. i mounted my b16a AC compressor to my gsr block, using the del sol vtec AC mount though. i have a del sol btw. if u have an EG chassis u'd probably need the del sol AC mount, since this was the only eg chassis that came with a b series.
krazy
EK_4_ME
Apr 19, 2012 07:27 PM
phantom_sol
Sep 24, 2010 09:11 AM
spike
Jul 12, 2004 09:23 AM
spike
Jul 9, 2004 12:24 PM
