B16Z6 engine problems
Old Jul 25, 2002 | 01:05 PM
blakflagg's Avatar
Default B16Z6 engine problems
Ok here is the story: I bought a 95 D16Z6 motor and swapped it into my 89 CRX. At first the there was no fuel getting to the injectors then I got a tip that I had the wrong injectors so I swapped them too, it worked, but i was still having starting issues, i found out that the distributor was wired wrong, it turns out that I had the CYL sensor and the Crank angle sensor mixed up so I changed it to the proper wiring pattern. Now the engine Starts up every time and even idles. But the engine will not go over 3000 rpm and I am getting a code 4 (crank position sensor error) is it the distributor that is blown or is my wiring screwed up?
BigbamaBen
Mar 17, 2013 12:09 AM
mikester1222
May 7, 2009 09:35 PM
Tad
Jan 25, 2008 06:36 AM
one_crazy_integra
Dec 22, 2005 09:31 AM
Acid832
Aug 9, 2003 12:25 PM
