B16a swap into 91 hatch. What ecu and potential wiring problems can be expected?
I'm going to hopefully be swapping a B16a into my 91 hatch and was wondering what kind of problems I might run into? Also what ecu should I use? Any help would be appreciated. Thanks
Re: B16a swap into 91 hatch. What ecu and potential wiring problems can be expected? (civichopeful)
i dont think you gonna run into any trouble at all. probably just the wiring. just use the obd-0 ecu the one comes with the swap. one more thing dont forget to buy Hasports shift linkage and motor mounts. you are going to need them.
Re: B16a swap into 91 hatch. What ecu and potential wiring problems can be expected? (92_B18c5hatch)
what model is your car. DX, Si? that is going to tell you how hard wiring is going ot be.
Re: B16a swap into 91 hatch. What ecu and potential wiring problems can be expected? (CR-X)
My car is neither. It's the cheapest base model you could buy. Just a plain old civic. Thanks for the responses.
if its a jdm motor...you'll hafta add wires for the second o2 sensor...v-tec solenoid , pressure switch and add wires for the extra injectors...plus get the injector resistor box. it very easy and straight foreward. tech.hybridgarage.com/tech/4gtech/index.html this should help you out.
good luck!!
good luck!!
Re: B16a swap into 91 hatch. What ecu and potential wiring problems can be expected? (forcfedcivic)
Thanks for the info. I will let everyone know how it goes.
dohdoh420
06-20-2007 09:03 PM
ridestrt
02-10-2003 11:24 AM
