need answer ASAP...gsr axle in del sol hub...does it work?
my friend is swapping a gsr into a del sol. He is having problems with the gsr axle fitting the delsol hub or spindle or whatever it is called. Does he need a civic hub, or does it just take some finese to make it work with the del sol's? thanx
Re: need answer ASAP...gsr axle in del sol hub...does it work? (DC2_Jspec)
it should fit right in.... mine has a gsr axle in a 93 hb and the setup came out of a del sol... it just has to slide in there... hope it helps, l8rz
Patrick Leist
05-06-2017 09:45 AM
CKPerformance
14
09-12-2007 10:54 PM
KyleVA
02-17-2007 07:02 AM
kay_animation
02-03-2003 06:04 PM
