Correct Gap for JDM B16A sparkplugs ??
Ive heard .35 alot, but as I was reading the UK JDM Manual it says 1.1! Thats a hell of a gap ....Just curious on what you guys are gappin at. tHanks
Devin
Devin
Re: Correct Gap for JDM B16A sparkplugs ?? (Lyonel)
Which plugs are you guys using? I'm running BKR6E-11s right now... not sure if that's right since everyone says to get BKRE-N11s... is there a difference?
Re: Correct Gap for JDM B16A sparkplugs ?? (raene)
HEY DarkSubRosa
U have a JDM B16A2 in ur DX civic right? I have a same car and engine as u. can u tell me how many wire u have run to get the engine running right? Do u have to hook up the A20 (EVAP PURGE) wire to the ECU? I run a Vtec wire to D4, Knock Sensor to D6, do u have to wire anything beside that? PLEASE HELP
Re: Correct Gap for JDM B16A sparkplugs ?? (power_civic)
there are 4 wires you add.... im not exactly sure where to pin them in, im pulling the motor out and putting it into a hatch, i gotta get the schematics for the wiring so i'll know in a couple days if you can hold off... but its 4 wires, knock sensor, two from the solenoid, and another for the pressure switch i think.... im getting the diagram on it to redo the swap so if you need to know i'll find out.... late
oh yea...and just to be sure what your talking about..no such thing as a JDM B16A2.....its just a B16A.... second gen hydro tranny from a 94 SiR...B16A2's are USDM Si motors from the 99+ coupes.
[Modified by DarkSubRosa, 5:21 AM 7/26/2002]
