Can you make large amounts of tourqe with B16s?
Re: Can you make large amounts of tourqe with B16s? (Touch)
Long intake manifold runners, with angle grind on the mount of it for smooth intake flow, large throttle body, and 4-2-1 header. Also, retard timing a few degrees to move the power lower in the band, tune the cams with cam gears for the same. Getting a shorter geared tranny and bigger final drive will help multiply the effect. I can't see getting more than 15-20 ftlbs extra though with just bolt ons, will have to go with head milling or higher compression pistons, and while you have the engine apart...
Re: Can you make large amounts of tourqe with B16s? (johnd)
ok lemme explain this simply
if you want low end (torque) -> you loose high end (horsepower)
if you want high end -> you loose low end.
Re: Can you make large amounts of tourqe with B16s? (KAMiN)
I'd planned on building up the bottom, then slapping a drag III turbo on it. I figure that should put me in the low 12,s high 11's with full cx trim.
What do you guys think?
TunerShark
13
10-19-2006 08:13 PM
