B16b with 89 crank
B16b with 89 crank
I will be using B16b block with b20b crank & rods, my question is what main bearing and rod bearing should i use? is it the size of the b20b bearings for the main bearings or the b16b size main bearings? I think the rod bearing should i used is for b20b since im using eagle rods for b20b. Also is it the main caps of b16b the same as the B20b? what main caps should i used to the 89mm cranks to be drop off to B16b block?
Re: B16b with 89 crank
main bearings of the b series are all the same. rod bearings will have to be b16a or b20. you can use b18c ones but you'll have to get the rods retanged.
Try to search online for a B18 haynes manual, for the complete detail specs... I got the specs but its on my other pc.... If you have difficulties with the build or specs, PM and I may be able to help you...
JDM turbo DC
11-28-2006 12:37 PM
