New Dyno Numbers, so getting close to 200
I had a recent incident that I ended up bending most of my intake valves on the dyno with skunk2 stage 2 cams. I returned back to my stage 1 cams and a DPR reworked head. They put their custom valves, valve guides, seals and valve job and also cleaned up a poorly ported head. I returned to the dyno last night and I am very happy with the results. About 3 hours on the dyno, and we got this:
Setup is B18C1 block, JE 11.5:1 CR pistons, B16A head, DPR valves, valve job, mild port and polish, Skunk2 Stage 1 cams, JDM DC 4-1 header, test pipe, APEXi N1 catback, SRI w/ icebox, Lucas 440cc injectors, Hondata s200. So close to 200, but I think with the addition of a Hytech or SMSP header and a 2.5" catback, it should be very easily attainable. Props to my tuner Mikey (fuccarlos) and DPR for the head work and quick turnaround time.
Edit:
200 HP open header run
Modified by AzSi22 at 9:02 PM 7/2/2004
Modified by AzSi22 at 7:18 PM 7/5/2004
Edit:
Re: New Dyno Numbers, so getting close to 200 (AzSi22)
Are you running 440cc injectors because someone told you to or because its what you decided on? Just curious cause I bought 370cc for my build up and im running 13:1 cr. Just curious.
Re: New Dyno Numbers, so getting close to 200 (PreStaged12s)
I didn't want to not have enough fuel, so I decided to have plenty of reserves. Plus, I am close to 70% duty cycle on these now. So with 370's, I'd probably be cloesr to 80%.
Re: New Dyno Numbers, so getting close to 200 (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke »</TD></TR><TR><TD CLASS="quote">Thats pretty solid power considering you were running stage 1's.</TD></TR></TABLE>
True that.
Nice numbers!
True that.
Nice numbers!
Re: New Dyno Numbers, so getting close to 200 (RangerDan)
whoever you had tune your car is pretty darn good
your graph shows an almost perfect curve and you cannot even see where VTEC engages
big strong guy
You should be able to Get Over 200whp with Skunk Stage 1's.....
Ill put money you can get to atleast 200whp with just the change to a Toda or Like Header, and 2.5" Exhaust!
Eric
Eric
Re: (HONDATUNER92)
I think I have plenty of capacity left with the 440's. I'm at about 72% duty cycle, so I have some to go. Thanks for the comments. I think the motor has 200 in it open header, I may try to do this soon. I have kteller.com 2.5" exhaust coming and will be ordering a SMSP or Hytech header soon.
Re: (DefiantGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR »</TD></TR><TR><TD CLASS="quote">what kind of IM are you running? type R, skunk2, AEBS?</TD></TR></TABLE>
Whoops, forgot to add that. AEBS manifold, ported the first 2 inches in the runners and the throttle body opening. JG bored 64.5mm TB. Hondata IM gasket.
Re: (DefiantGSR)
This dyno is at a higher elevation too, but its the same one I've always dynoed at. So I think at a lower elevation, my numbers may be higher. I think the header is my restriction right now. I think that will make the motor package complete.
Re: (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 »</TD></TR><TR><TD CLASS="quote">This dyno is at a higher elevation too, but its the same one I've always dynoed at. So I think at a lower elevation, my numbers may be higher. I think the header is my restriction right now. I think that will make the motor package complete.</TD></TR></TABLE>
Re: (AzSi22)
What did you change? another reason i love skunk2 stage 1's look how flat the TQ curve is, must be fun to drive at any rpm
Re: (AzSi22)
No thats not true. It says sae right on your dyno sheet and that should be sea level numbers. I suppose theyre could be a little difference but Im sure that things like barometric pressures, heat and humidity have a larger effect.
Also depending on where the tuner has the little temp thingy (tech lingo lol) makes a difference as well.
We tune at around 5000 ft or so if that makes you feel any better.
Andrew Sutherland
12-21-2006 04:06 PM
