HELP HELP HELP!!
Old Nov 20, 2006 | 06:23 AM
EG6_GSR's Avatar
Default HELP D16Y8 shut down on Freeway!
I was driving my car (98 Civic EX) with a basically stock Y8 under the hood besides an intake and I was doin about 100 MPH and all came to a hault... the RPM's droped the engine shut down, when pulled over the car will still turn over with no problems and no questionable noise (sounds great) but it will not start./.. do you have any Ideas??? Please I need my car back up and running before thanksgiving so I can go home!!! Please help ask around!! thank you so much!!
Modified by EG6_GSR at 7:36 AM 11/20/2006
Old Nov 20, 2006 | 06:55 AM
Runnerdown's Avatar
Default Re: HELP D16Y8 shut down on Freeway! (EG6_GSR)
Sorry to hear that.....but it could be so many things. Cant think of where to start guessing.
Old Nov 20, 2006 | 07:21 AM
EG6_GSR's Avatar
Default Re: HELP D16Y8 shut down on Freeway! (Runnerdown)
thank you, but please Ideas!! somewhere to start!!!
Old Nov 20, 2006 | 07:50 AM
Runnerdown's Avatar
Ok, i'm gonna shoot for distributor issues? maybe the rotor screw fell off. maybe the ignitor or coil **** the bed?
Old Nov 20, 2006 | 07:55 AM
EG6_GSR's Avatar
ok I will look at that... what else???
Old Nov 20, 2006 | 08:21 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6_GSR &raquo;</TD></TR><TR><TD CLASS="quote">ok I will look at that... what else???</TD></TR></TABLE>
Out of gas
90% of Honda no start problems can be traced to the distributor. Failed igniter or ignition coil, or a rotor screw that came out.
Old Nov 20, 2006 | 08:23 AM
EG6_GSR's Avatar
Default Re: HELP D16Y8 shut down on Freeway! (b19coupe)
and that would cause it to shut off on the freeway too???
Old Nov 20, 2006 | 08:25 AM
b19coupe's Avatar
No spark will cause it to shut off anywhere it happens. Freeway, parking lot, the track, your driveway, during your get away from a bank robbery...
Old Nov 20, 2006 | 08:26 AM
EG6_GSR's Avatar
ok I will look at it! will I need to replace the whole thing?? or just parts?? where can I get the parts and what is the Estimated Price of the Project??
Old Nov 20, 2006 | 08:27 AM
Furyof4's Avatar
Does it turn over really fast when you try to start it? Check the timing belt.
EG6_GSR's Avatar
I just got back from Guam I was there for two years so all the assistence is very very helpful thanks!
Old Nov 20, 2006 | 08:44 AM
bluetintruben's Avatar
START WITH THE BASICS, CHECK FUSES, SPARK FUEL, THE PRIMARY ON WHAT A CAR NEEDS TO RUN! THEN CHECK THE OIL FOR METAL SHAVINGS!
Check for fuel delivery! make sure the fuel pump is delivering!
Old Nov 20, 2006 | 08:51 AM
EG6_GSR's Avatar
Default Re: (bluetintruben)
Thanks again guys!!
civictypetom
Jul 13, 2008 11:08 AM
1ntegrat10n
Aug 15, 2007 07:50 PM
greasemonky50
Mar 20, 2006 05:25 AM
