b20 build
couple b20 vtec questions
i'm doing a b20b with b16a head. the first thing i bought were standard size main and rod bearings. did i mess up already? my friend told me that you buy the bearings right when you change them for they may not be a standard size... and i've heard that if you have bigger cams it'll hit the pistons. i plan on getting new higher comp. pistons, and also some bigger cams, will it still be a problem with the new pistons?
Modified by B20TRIZ at 8:24 PM 11/18/2006
Re: (BILLY_BLING)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BILLY_BLING »</TD></TR><TR><TD CLASS="quote">get some rs cast pistons,they will fit on stock rods, shot peen rods and you will have a strong bottomend, I used stock size rod and main bearings</TD></TR></TABLE>
what he said but also use arp rod bolts with the stock rods
Re: (acydphryck)
If you already have the eagle rods use them. I have eagle rods with ARP rod bolts and ARP headstuds. Then i bought wiseco 12:1 compression pistons with buddyclub stage 4 cams and i have no problems with piston to valve clearance. If you plan on buying a bigger cam then you have to upgrade the valve train so its gonna get expensive. Good luck
nengx07
04-27-2011 07:47 AM
