Putting ls in on saturday, a few Qs.
i will be receiving my swap on friday from IAS, and i had a few Qs, some may sound stupid but bear with me. Im assuming the tranny will be drained and so what tranny fluid that i can get locally(not order) do you guys recommned. what maintenance should i do to the motor(timing belt, plugs,etc)? the swap will be fairly straightforward i know, is there anything else you guys recommend to do, im putting in my new action clutch too, i should get the flywheel resurfaced shouldnt i? thanks. any other help welcomed too.
Re: Putting ls in on saturday, a few Qs. (blufke)
I always use Honda tranny fluid. As far as what to tune up, it depends on how many miles are on it. Is it about time for a timing belt? If not just do the norm ie. cap, rotor, wires, belts. If you are putting in a new clutch I would recommend resurfacing the flywheel, but alot of places dont.
Thanks, J
Thanks, J
things like:
pilot bearing,
dizzy cap, rotor
spark plugs
oil, oil filter,
any leaking seals?
RESURFACE the flywheel!!!
hth,
t..
stuff like that...
pilot bearing,
dizzy cap, rotor
spark plugs
oil, oil filter,
any leaking seals?
hth,
t..
stuff like that...
Re: Putting ls in on saturday, a few Qs. (tinkerbell)
yeah, im taking it to napa to resurface. how much is a new cap + rotor? im doing plugs, maybe timing belt, all fluids. can i only get honda tranny fluid from a honda dealership? anything else?
I recommend changing the water pump and timing belt at the very LEAST. Unless you know for sure the engine has low mileage. It is so much easier while the engine is out of the vehicle, and you will kick yourself later if the belt breaks and you bent valves.
Also, dont go cheap on the distributor rotor if you change it. Ive seen some aftermarket rotors become loose or melt. Get at least a OEM rotor and make sure you use loctite on the screw that holds it in place.
Re: Putting ls in on saturday, a few Qs. (HandCommand)
are autozone or checker parts good enough? like timing belt,water pump, cap,rotor? and how much do they usually run for? also, what tools do i need aside from the standard sockets(i have a cherry picker too)? i.e. big socket for spindle nut or whatever its called. basically i want to have everything covered, gimme a shopping list.
I wouldn't purchase parts from Autozone or other autoparts stores. Do it right and go to Honda to purchase these parts. The Honda tranny fluid you can buy at Honda/Acura Dealerships and I believe some online places. Other than those places I don't know.
Thanks, J
Thanks, J
Re: Putting ls in on saturday, a few Qs. (IlikeTODA)
what about the tools, and anyone elses opinion on the autozone or checker parts?
[Modified by blufke, 8:54 PM 8/7/2002]
Re: Putting ls in on saturday, a few Qs. (madtownhonda)
im sorry, i need to know what extra tools other than a cherry picker and the standard sockets do i need(i.e. really big sockets, specialty tools, etc)? how do these prices sound too:
Rotor-22
Cap-26
Timing Belt-61
Water Pump-60
All OEM honda parts from dealer.
Rotor-14
Cap-12.99
Timing belt -37
Water Pump-37
All autozone and napa parts.
[Modified by blufke, 10:21 PM 8/7/2002]
Rotor-22
Cap-26
Timing Belt-61
Water Pump-60
Rotor-14
Cap-12.99
Timing belt -37
Water Pump-37
vlc92189
14
11-27-2007 05:22 PM
The Droogan Leader
10-23-2005 07:04 PM
