Help with vtec soleniod troubleshooting
New User
I keep getting code 21 on my new ls/vtec swap. I have a pr3 computer in a crx. Anyway to check the computer?? I have good oil pressure and I have cleaned and add new ground wires. The soleniod valve works fine if I jump it to the battery. The screen is new and the valve inside moves freely. Help Help.
Re: Help with vtec soleniod troubleshooting (KAMiN)
PS how is this for luck!!
this post has a pic of the ECU pinout you need!!!!
https://honda-tech.com/zerothread?id=253354
cool!
t..
cool!
t..
New User
Re: Help with vtec soleniod troubleshooting (tinkerbell)
I think that you all help me find my problem. I will know tonight. The wiring that I got off of the net at another site is wrong. But to answer the oil ? I have my oil line and oil gauge tee in together.
New User
Re: Help with vtec soleniod troubleshooting (DTAYLOR)
GO vtec Man it works better with the wires in the correct place. But I still have a little oil leak where the soleniod bolts to the block. A type r gasket seem to be a little thin. And my timming marks do not line up. I have the idle at 750 and the jumper plug in.
New User
Re: Help with vtec soleniod troubleshooting (SuperCivic)
I think that I am going to try the sealant and the gasket. I will call to get a price for the piece that bolts to the head.
New User
YES vtec is running ok. But I went to set the timing and the marks are way off. I put the rpm at 750 and did the jumper wire. But my timing is to far advanced. The car run good and it does not act like it is way of but the light says it is. I cut off some of the dis holes and got it alot closer but it is still of the marks.
dumb question - but are you using hte No. 1 spark plug as the trigger? the one closest to the timing belt?
t..
t..
New User
Yes number one plug. I am using a ls distributor and I bet that if you cut off the ear like I did it will work but it does not sit in the same place as a vtec distributor would.
bigislandc2
09-02-2006 10:37 PM
05 S2K Stoner
10-28-2004 06:39 PM
