intake dont fit???
H-T Poker champion
Re: intake dont fit??? (hybrider93)
Modifications must be made to the pipe in order to make it fit properly. Try a search on it cuz im not too sure on how to do it.. i think you have to take 2 inches off it or something weird like that. Try a search, good luck!
Re: intake dont fit??? (dose)
You have to cut that bracket it has. I also had to take out a nut that was holding the AC lines so that i could move them a little. Other than that just have to use some elbow grease to get it in there. Not too hard. Let us know how it goes
Re: intake dont fit??? (jdmhatch)
If you have a/c it is not bolt in. One way is to cut the pipe and put in a AEM bypass
That should help you get the pip where in needs to go. I just took out the A/C
Philip
10
06-03-2003 10:32 PM
Civichatch972
19
02-02-2003 07:15 PM
