What kind of numbers am i gonna get?
Re: What kind of numbers am i gonna get? (AcuraTypeR)
Low to mid 14s, with a B18C5 if you can launch a car. Civic Type R engine, a little slower. GSR about the same.
I say that because an USDM ITR, on its softer tires than what an otherwise stock EK comes with, can run 14.7-15.2 if the driver is any good, but it should be heavier than the hatch.
You can't just say engine X in chassis Y will run a 1/4 in Z time. What tires are you running? Lower tire air pressure in front, raise in back? What size and weight wheels? Height above sea level? Air temperature? Humidity? Track surface temperature? Intake & exhaust when you drop in the engine? Can you drive?
Look, the only reason I answered that question is because you put "thanks." People on this board hate questions like this because of the subjective variables mentioned in the previous paragraph.
Re: What kind of numbers am i gonna get? (Rembrant Q. Einstein)
Thanks for the answer.
I was basically asking the question if an ek hatch was with one of the three engines in complete stock form, what would be some times. If i put some light 15's, exhaust, and intake, i would assume the times would be "faster".
boostd92
11-06-2006 01:08 PM
