I need some swap help b18c-hatch deal
I just recently purchased a 01 b18c and i was wondering if i had to get a new ecu,dis,altinator, or will the OBD2 just plug in?
So basicly what i am saying is what do i need to do to put a 01 b18c into my 92 dxhatch
Re: I need some swap help b18c-hatch deal (Civ-JDM)
u will need Engine, intake manifold, fuel rail w/ injectors, throttle body, throttle cable, exhaust manifold, alternator, distributor, ECU, transmission, starter, clutch, pressure plate, flywheel, axles, intermediate shaft, shift linkage, engine mounts, transmission mounts, radiator hoses all this should of came with the motor i might be missing something else not sure.
Re: I need some swap help b18c-hatch deal (drvfast)
no all of that came with it except a ecu, but the engine and everything is a 2001 so what ecu should i get, because dont i have to convert to obd1
plug everything in and buy a obdI ecu. everything should plug in under the hood using the obdII harness.
[Modified by Malachi, 12:03 PM 8/8/2002]
Like Malachi said. All you need is a OBD1 GSR ECU (p72). The engine hardness sould bolt up to your harness in the Civic. Drop the motor in, hook up the harness, plug in the P72, give it a try.
It's simple as plug and pray.
Derek
Derek
Re: I need some swap help b18c-hatch deal (DerekY)
also in a 92 you should only have to run 1 wire. check all of them with the diagram here http://hybrid.honda-perf.org/
