harness options for b16a2
Old Aug 4, 2002 | 03:12 PM
hondaeg5's Avatar
Default harness options for b16a2
i have a 92 vx with a ls swap/gsr trans. im buying a b16a2 longblock from hondamotors online. can i use my stock vx harness? can i use the ls harness and add what i need? can i use a obd1 harness on a obd2 motor?,assuming i get the proper ecu? TIA
Old Aug 4, 2002 | 07:24 PM
IlikeTODA's Avatar
Default Re: harness options for b16a2 (hondaeg5)
Not sure about which harness, I have heard you can use the VX one though and that it has the VTEC wires already. If you have OBD2 injectors alternator or distributor you will have to use the plugs from the OBD2 harness. If those 3 parts are OBD1 then you can use the OBD1 plugs.
Thanks, J
jazzRS
Sep 28, 2012 03:16 PM
CivicB18C1
Jun 13, 2008 05:47 PM
killerB16A
Jan 16, 2007 11:01 AM
Henry HA
10
Jan 7, 2004 08:33 AM
HondaCutter
Sep 19, 2002 01:10 PM
