A/C problems with my gsr in my eg
I gots a 99 gsr motor in my eg. My a/c bolts on, but no place to bolt on the belt tentioner. Should I try using a different lower mount bracket? Let me know what I should do. Maybe just take a/c out all together. go faster then. Wisconsin summers aren't that hot anyway. but why does my a/c bolt on to the bracket, but then have no place to put the tentioner pulley on. Maybe JB weld er on there. NO
Let me know what you all think
Re: A/C problems with my gsr in my eg (Rspool)
OK. my A/C compressor fits on the a/c bracket. But the pulley that tightens the a/c belt doesn't fit on the bracket. (bracket should have 2 holes to bolt the pulley onto) But I was wondering if I should go with a different a/c bracket or just take the a/c out. If I tried to sell the car, it would be higher value if it still had a/c, right?
Re: A/C problems with my gsr in my eg (CivicNewbie)
im using my stock a/c compressor, with the gsr bracket. I have the a/c bolted on my 2 bolts.
Re: A/C problems with my gsr in my eg (92hatchy)
You need to use the Teg A/C tensioner.
The Civic A/C belt is too short and the Teg belt is too long you need to get the 4PK785 from Autozone. You prolly need to make some custom bracket to bolt 1 more bolt. Go here to see the pics of my ghetto custom piece to bolt the 3rd bolt in. http://www.angelfire.com/tx/no11/AC.html
Can I just pick up a teg a/c tensioner from any auto place too??? Ill get that belt, and rig it up like you said.
Nop. Damit. do you know where I could get that from? I just got the bracket. I didn't get the tensioner.
extremeEK00
05-08-2010 09:00 AM
miketegra
06-05-2006 10:17 AM
lowbudget88si
07-22-2003 08:48 AM
tvrvic
08-07-2002 08:44 AM
