B18c1 in a 4g hatch w/b16
There was post kind of about this (Yes, I did a search), but someone mentioned needing to switch 2 wires, chipping the ecu with the Mugen proggy, and getting a Skunk2 IM.
I'm going to try and get an obd1 (does that even matter?) b18c1 longblock. I was going to swap over my obd0 electronics from my Gen 1 B16 (dizzy, alternator, what else?) and run with the chipped ecu on the Skunk2 IM. What I'm wondering is the wiring (sensors,etc) difference between the 2 motors and what I'm gonna have to change. the B16 has 2 o2 sensors where the b18c1 will only have 1, and the b16 has a knock sensor which the b18c1 does not, right? Thank you for your help.
Also, what do b18c1 longblocks with reasonable mileage go for?
Edit: in EF forum, good thread if anyone's curious https://honda-tech.com/zerothread?id=242829]
[Modified by ricodemus, 2:43 PM 8/7/2002]
[Modified by ricodemus, 8:10 AM 8/8/2002]
Re: B18c1 in a 4g hatch w/b16 (ricodemus)
a buddy of mine has a gsr in a 4g hb and is using a pm6 (4g si obd0) with the zdyne one wire conversion...no knock sensor and one o2 sensor and is using a skunk2 mani also...the car runs great. he did buy a vafc to pump the fuel up a bit.
he paid 1200 for his c1 longblock w/o crank pulley and a motor mount bracket
IM'ed you back
but...
-use your B16 dizzy, alternator, and chip your ECU with the Mugen chip.
-the Mugen chip will eliminate the B16 secondary 02 sensor, knock sensor, and the rev limiter.
-the VTEC activation point on the Mugen chip is 3800 rpm (really low) so at some point you mite want to get a VAFC to raise this.
-the Skunk2 Mani will eliminate the B18c1 butterflies.
-the 2 wires on the stock ECU harness that need to be changed are the VTEC and ?? - hope someone can fill in the blank here. the VTEC one goes to the VTEC solenoid and the other one to ?? (sorry I forget...)
-altho I just had a thought that you must already have the wire running to the Vtec solenoid and the other necessary one on the B16 tho - so it might be even easier (I went straight to the B18 so I never had my car previously wired for a B16)
-I picked my b18c1 full swap up for $4000.00 CDN with a full rebuild, ITR pistons, cams, and JUN cam sprockets. This was from a buddy tho. I've seen them as high as $5800.00 CDN at the wreckers.
hope this helps...
peace
but...
hope this helps...
peace
Re: B18c1 in a 4g hatch w/b16 (dumbchild)
oh yeah - the B16 ecu chipped with the Mugen proggy will be more than enough fuel - maybe even too much - I have to lean mine out with the VAFC to pass aircare.
How about if I can get my hands on a b18c block? Is that a good combo (with my b16 head)? Is that a bolt-on process (head to block)? Thanks. These b18c longblocks are steep, still wondering if its worth it.
i dont see why it wouldnt bolt up, they were bolt from vtec motors to begin with and the b16 is basically an unported c5 head. however, when you bolt a b16/c5 head on a c1 block it drops the compression...i think it has something to do with the combustion chamber designed on the head, but i am not exactly sure.
incase you have not seen this before, you can play with compression numbers here...
http://www.c-speedracing.com/howto/c.../compcalc.html
what about just sleeving the b16 and punching it out a little?
Re: B18c1 in a 4g hatch w/b16 (Jeff C)
Edit: now I'm reading some archived threads and it looks like it's not a great idea for the cost to bore a b16 to 84mm. I guess I can't win here.
[Modified by ricodemus, 8:12 PM 8/8/2002]
nomotor
07-31-2004 09:36 PM
Kyle101
09-19-2003 02:49 PM
