do I need the del sol ac bracket for b series into ek?
I dont plan on keeping ac, should I still invest in the ac bracket? does it help limit engine movement, Ive heard of peep's driver side mounts busting because they didnt get this (if memory serves me correct) ? what do you guys think?
Re: do I need the del sol ac bracket for b series into ek? (SilverCIVIC96)
you can use any b series ac bracket. you only need the delsol if you want to keep ac.
Re: do I need the del sol ac bracket for b series into ek? (tonyxcom)
oh, so if I dont need ac, I can just use the one that comes w/ the swap? do swap usually include the ac bracket?
Exactly.
Swaps should come with the A/C bracket.
FYI, I got the delsol bracket so that I can keep the AC in my 96CX.
I have an ITR bracket, but it doesnt have the stud and bolt that screw into it. I had to transfer them over to my del sol bracket.
I need help on that AC also. The guy quoted me 2 pieces for that, he said one is for 21 bucks, the other is 98 bucks. I think the 21 bucks is for the belt tesion. Can I use the one came off my B18c1 or do I need that one also? Where can I get the bracket for cheap? Thanks
Re: do I need the del sol ac bracket for b series into ek? (92SiB18C1)
The bracket is two peices AND the tentioner pieces.
Bracket is bout 100 and the other part (19) is 5 bucks
Dont know what the tentioner runs
015 BRACKET, AIR CONDITIONER 21.78
020 BOLT, SPECIAL (10X30) 2.66
022 BOLT, HEX. (8X84) 1.64
023 NUT, HEX. (8MM) 0.35
016 PULLEY COMP., IDLE (STAMPED PART) 34.37
017 COLLAR, IDLE PULLEY 3.28
021 BOLT, SOCKET (10X28) 3.29
You can get the bracket from http://www.hparts.com
I have the part number listed at http://www.jspectuning.com/6gen
Re: do I need the del sol ac bracket for b series into ek? (Trey)
Trey: FYI the RR tranny bracket is wrong on your site. the P/N is 50827-s04-n10
BTW i have a question. how did u put on the mount below the timing belt? it says to use the 99 si mount. did u remove the crank pulley? thanks
[Modified by A-Spec, 11:21 PM 8/12/2002]
jayWknight
09-08-2009 10:28 PM
keychild486
07-11-2008 03:31 PM
