Ok guys WTF am I doing wrong????
Ok. I swapped an H22 in a 99 civic using the ek-22 kit from HCP....anyway I bought the axles that they reccomend (which are the 94+ teg axles).....the driver side axle splines in to hub and half shaft but when I go to put the ball joint back in its socket it will not go. It seems that the axle is about 1/2 inch too long so it isnt alowing the ball joint to go back in......what axle is short enough to use in this case? Any other suggestions?
Thanks,
Mark
Thanks,
Mark
Re: Ok guys WTF am I doing wrong???? (SlvrEj6Dx)
Nevermind....I found a few diff. set ups that people talked about.....now can anyone tell me which is shorter.....between the 86-89, the 90-93, and the 94+???
Thanks
Thanks
BOMBCRU
07-30-2006 06:39 AM
Jared
07-20-2003 06:46 PM
