Which AC Bracket for a 93 Civic with B18C1
Re: Which AC Bracket for a 93 Civic with B18C1 (gp93DX)
It will work, but your compressor won't be held on by all 4 bolts. You can use a Delsol AC bracket and all holes will line up.
Thanks, J
Thanks, J
Its not just a Del-Sol A/C bracket...it has to be a 94-95 Del-Sol VTEC A/C/ Bracket...here is the part number for it
38930-p30-000
38930-p30-000
Re: Which AC Bracket for a 93 Civic with B18C1 (1fastVX)
38930-p30-000
38930-p30-000
Re: Which AC Bracket for a 93 Civic with B18C1 (DaiJekBok)
Do NOT use the AC bracket with P30 in the part number.
The '94-'95 DOHC VTEC Del Sol AC bracket has P54 in the part number. That is the one you want. Trust me on this one. I have bought a dozen or so and they have all worked on the swaps I have done.
-kenji
-kenji
Re: Which AC Bracket for a 93 Civic with B18C1 (kenji)
I used a '94 del sol vtec bracket to mount the compressor on my old LS motor (in my old dx hatch), worked perfectly too (too bad it got totaled b4 I got to charge the ac).
Re: Which AC Bracket for a 93 Civic with B18C1 (Death Scythe)
Both the P54 and the P30 will work (hold the motor in place).
It depends on if you keep your AC and use the Civic compressor.
If you have a 92-95 Civic, you need the 94-95 del Sol AC bracket.
If you have a 96+ you need the 96-97 del Sol/ 99-00 Si AC bracket.
Simple enough.
I used the P54 form my 98 Civic CX.
Part numbers are listed at http://www.jspectuning.com/6gen/
[Modified by Trey, 2:28 PM 8/10/2002]
Simple enough.
Re: Which AC Bracket for a 93 Civic with B18C1 (Trey)
OK...thanks guys...no P30s here i am doing the P54 part number. One other question though, is motor mount part of the ac bracket or is that a separate item. meaning if I get the Del Slo ac bracket can I use the GSR lower driver motor mount or does the del sol bracket come with a mount.?
G
[Modified by gp93DX, 7:47 PM 8/11/2002]
G
Hey Kenji,
I need a chipped p28 ecu for a (obd 1 ) b18c1 with I/H 4into 1/E. I also want to add at some point the 70mm throttle body and Skunk 2 stage 1 cams. How much can I get a chipped ecu from you for..and which program do you recommend.? Email me privately at gpser96@hotmail.com...I heard your ecu's ROCK..!!
[Modified by gp93DX, 7:50 PM 8/11/2002]
The mount is seperate from the bracket. I used a GS-R mount and shaft (for lack of better term) that threads into the bracket. The mount then slides over that.
jayWknight
09-08-2009 10:28 PM
moz92
08-13-2008 10:55 PM
eric.
08-18-2005 06:15 PM
