New block from Blueprint Racing!
Just wanted to say thanks to my boys Ben and Robert at Blueprint Racing for the new block! Car is gonna love it! :up: Just wanted to share some pics! Thanks guys!
Re: New block from Blueprint Racing!
Thanks
Yeah for dragracing. Here is wisecos explanation: Vertical gas ports are primarily used in drag race applications. Lateral gas ports are more often used in circle-track and road-race applications where carbon build up can occur. When gas ports are used, pressure is directed to build up behind the compression ring and seal it against the cylinder wall. This helps prevent ring flutter and extends the power curve upward in the RPM range. Vertical gas ports have the holes drilled from the deck of the piston into the top ring groove and behind the ring. Lateral gas ports are drilled through the bottom side of the top land and extend to the back wall of the ring groove.
