checked cel code and ..........
ok o i did this for the first time , and my cel started to flash , it stayed consistant with long pauses and then a flash , i counted the times it flased . the first time was 45 , i think that was a mistake cas i think i took to paper clip off the prong , so i tried it again and again long pauses then a flash , i counted 200+
wth is going on ......
. wth is going on ......
Hey guys I got a question , I'm suppose to be getting my car tunned soon for next months track ! I haven't been able to find out why my car is not getting any spark to any of the cylinders . Its a 94 dx civic with a built b20v , its a obd2 bottum with a obd1 head , I got hondata s300 off a friend that ran it on his single cam ,
Not my question is , my bottum end is suppspose to have a crank sensor but I don't got one plugged in , my ecu started up my boys b16 civic with no promblems so ecu is fine , reminder his motor had a cranksensor , now since I don't got a crank sensor plugged in would that be the reason why my car isn't gettting any sorts of spark ??
I had my tunner put a stock GSR mapp on my computer and he disabbled the crankk sensor cas I'm sure the old map was reading one but I didn't have one pluggged in ..
Any advice would be cooool , thanks honda-tect I hope u understand this
Dizzy is brand brandnew , when u say ignitioon u talking about the coil in the dizzy ??
Also grounds are good , thermestat ground is good , fuses are all good , main relay is good , firing order is right , idk what the promblem is
What about my ignition ? What do u check for that ??
and that could possibly be the promblem cas I did take out my dash , steering rack , and all that bogus when I did my brake line tuck....
delmo777
Oct 17, 2012 03:30 AM
