Questions/Suggestions for the last few items for my build
I'll start off with my build sheet.
Head:
B16 port n' polished, 3 angle valve job
Skunk2 Tuner Series valvetrains
Buddy Club Spec 4 cams(will be degree'd)
JG adjustable cam gears
Edelbrock Performer X Intake manifold(still have to buy)
Professional Products 68mm throttle body
3" tunable length short ram intake
BPi velocity stack and filter(still have to buy)
Block:
LS Block 81.5 mm
LS crank balanced and micropolished
ACL Race Bearings
Wiseco 12:1 pistons
Eagle H-beam rods
Ok I still need buy a good BUDGET race header that allows me to keep A/C. I know I will get bashed about cheaping out on the header but I'm a full time college student and honestly don't have $700+ to spend on a header.
I'm torn between the kiddracing RMF Narrow and the Highend Tri-Y. Both keep a/c but I want to gain the most power from this setup as possible. Also injectors my builder told me to get atleast 320's, I did some reading and was debating on trying out the RDX injectors, they said you can gain 2-3whp because it atomizes fuel a certain way?? And I will be running 3" exhaust, through a vibrant muffler. Is that too big? I just want to break 220whp on 93 octane.
Any input or suggestions are welcome, thanks for reading.
Head:
Block:
LS Block 81.5 mm
ACL Race Bearings
Wiseco 12:1 pistons
Eagle H-beam rods
Re: Questions/Suggestions for the last few items for my build
..I'd suggest a better cam then the BC spec 4's...they will be the limiting factor
I'd go with a RMF replica and a 3'' exhaust.. to make better power..
Where can I find the Toda copy? I google'd it and found nothing. And Idk it's a number I want to hit and feel I can if, the car is my daily, so more than likely i'll keep it in a few months then sell it and get a stock itr motor.
no flaw my builder has a 550whp single cam and has built 4,5,600whp motors with no problems so far i have faith in him and my tuner.
if its built correctly and tuned properly, it will be just as reliable as stock...i daily drove my teg with a built ITR motor for 2 years every day without so much as a hic-cup
If you have such a great builder/tuner then why bother asking us for input? Hes building/tuning it ask him, he knows your setup better than anyone else on here. That is if you have a "builder/tuner"
Just for you;
waiting on BPI stack and throttle body should be here this week.
rick ef9
53
01-05-2006 03:19 AM
