Dizzy problem
Dizzy problem
I have swapped a H23A Blue top in my Prelude and in the past year I have been trying out to figured why my ecu always throughing out miss fire codes. I have mostly checked everything including, intake leak , egr , sparkplug , parkplug wires , even bough a new distributor cap and rotor , i have rewire 3 times the dizzy and nothing so i have plaining of installing the original dizzy that came with the original h22 with external coil but here is the problem.
An h23a blue top doesnt come with crank angle sensor at the crank , So i have to use the h23a original obd2-b dizzy to use the internal crank angle sensor orignal installed in the dizzy.
I would like to try an external coil dizzy but i need one with Crank angle sensor builtin since the original h22 dizzy doesnt have crank angle sensor. I'm not plaining to take out the timing belt and swap the whole oil assembly just to have the crank angle sensor at the oil pump.
Is there any where a dizzy that use external coil with builtin Crank angle sensor ?
thanks !!
thanks !!
