89mm crank in B16
Re: 89mm crank in B16 (Aquafina)
bump for you, its sucks when you make a thread and it quickly gets trampled by other threads.
By the way, I did something very similar, those pistons require a shortened compression height (as you probably already knew), ARIAS made me pistons with a smaller compression height, but they did not require buttons, as yours will, but I know arias can make those with buttons for you, as they told me i might need but mine worked out to not need them.
Re: 89mm crank in B16 (1600cc)
use the 89mm crank, stock length B16 rods, and custom pistons which the wristpin location has been moved up a length which is half of the difference in stroke between the B16 and LS.
my motor is being built right now. bottom end is done, waiting on the head from portflow... its a tech43 kit with 89mm stroke.
https://honda-tech.com/zerothread?id=1057340
more info there.
more info there.
Old Schooler
What kind of questions do you have regarding this set up??
This set up is very straight forward and works quite well.
I have had this set up in a car of mine for about two and a half years now and I have no issues with it yet. It makes 232whp with the s2 stage 2 cams 11.5 comp on pump gas. It smoked once because I put the wrong oil ring in it but its all good now.
BennyS
45
04-19-2016 10:27 PM
mrbsponge
04-28-2005 08:01 PM
Cidone
10-01-2004 04:43 AM
94tegra
01-26-2004 12:16 PM
