increased compression
how much of a hp increase can i expect from JUST <U></U> itr pistons in my gsr block? (trying to decide weather to rebuild it with stock pistons with boost or itr pistons all motor)
Re: increased compression (msmotorsports)
well im building the head, but i can still use those same parts on the head if i boost the motor with the stock comp. ratio. so i was trying to figure out the hp increase with the itr pistons to see if i can come close to my h.p goal without boosting the motor.
Re: increased compression (ITR-0877)
with a stock motor with only ITR pistons installed, i doubt u will see a 10 WHP gain. thats pretty high dont u think for everything else being stock.
Re: increased compression (boosted k20)
Dont hold me to this, but I have always heard that you can expect an 8-10 whp gain for every 1 full point gain of compression over stock ratio.
Anyone else heard of this?
Re: increased compression (hybrid_vtec)
I haven't heard an equation like that but it sounds about correct. For all motor setups compression levels that increased will not make you loose hp but cause gains. look at the B16B compaired to the B16a, granted the head cams etc. is different, but the pistons make a difference in a 1.6l.
Re: increased compression (phantom grey eg)
One point raised in compression nets around 2% power increase (that is, with proper tuning). So going from 10.1:1 to 11.1:1 will give you 2% power increase.
guess that means im gunna rebuild it with stock comp. ratio and throw on a base jrsc, that will put me at my 250 hp mark, sorry bill
Re: increased compression (green_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green_GSR »</TD></TR><TR><TD CLASS="quote">One point raised in compression nets around 2% power increase (that is, with proper tuning). So going from 10.1:1 to 11.1:1 will give you 2% power increase.</TD></TR></TABLE>
Are you sure about that?
sounds too little....especially if you have some other work done.
Re: increased compression (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit »</TD></TR><TR><TD CLASS="quote">
sounds too little....especially if you have some other work done. </TD></TR></TABLE>
This is what I was thinking.
it;s proably more than 2% buti think he was talk n about a stock motor. when i install my 11:1 P30 pistons, i better see at least a 10 whp gain and even more after tuning or else............... lol
