A/C Bracket...
Old Jul 15, 2004 | 05:37 AM
GiT LaO'd's Avatar
Default A/C Bracket...
Im planning on putting the A/C back into my civic real soon and wanted to know if it is necessary to use the DEL SOL DOHC A/C bracket??? Or can I use the GSR bracket?? I have a 95 JDM GSR motor in a 1992 Civic DX HB...Any info would be great...
Old Jul 15, 2004 | 08:16 AM
TECH43 RACING INC.'s Avatar
Default Re: A/C Bracket... (jaybee)
if you want to retain your a/c, use the del sol. no ac? gsr is fine.
Old Jul 15, 2004 | 08:29 AM
VTECVillain's Avatar
You need to use a Del Sol VTEC (B16A3) A/C bracket and the stock D series A/C compressor, lines, condensor, etc.
Old Jul 15, 2004 | 09:10 AM
GiT LaO'd's Avatar
So I dont need to use the GSR compressor...Can I still run R-134 coolant or stick with what the Civic ran...R-12??
Old Jul 15, 2004 | 11:51 AM
Default Re: A/C Bracket... (VTECVillain)
use the p54 94-97 del sol vtec bracket and belt, and you use the complete sohc a/c system.
Old Jul 15, 2004 | 12:38 PM
hondaZvic's Avatar
Default Re: (jaybee)
u should run r134a, if the compressor is for r12, u can convert everything to use r134a. its better that way.
r12 is fading out.
Old Jul 15, 2004 | 01:06 PM
GiT LaO'd's Avatar
The guy that might recharge my system was telling me he will just need a new filter, and then we can run R134...So running r134 in a R12 compressor is okay I take it with the right changes of course...
Old Jul 15, 2004 | 01:47 PM
beaterdriver's Avatar
sorry to get off topic, but i have a question, i am wondering do you have to use the del sol bracket if your gonna use a 00si a/c compressor
Old Jul 15, 2004 | 01:51 PM
GiT LaO'd's Avatar
I think if you want to retain AC with a B series in a 92-95 civic you have to for sure...
Old Jul 15, 2004 | 04:49 PM
Default Re: (beaterdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterdriver &raquo;</TD></TR><TR><TD CLASS="quote">sorry to get off topic, but i have a question, i am wondering do you have to use the del sol bracket if your gonna use a 00si a/c compressor</TD></TR></TABLE>
del sol bracket will not fit 99 si compressor.
BOTTOM LINE.
if you have a 92-00 civic. use a 94-97 p54 del sol vtec bracket, and retain your WHOLE stock sohc a/c system. don't even bother to unbolt anything, or evacuate the system.
Old Jul 15, 2004 | 07:52 PM
Default Re: (TECH43 RACING INC.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. &raquo;</TD></TR><TR><TD CLASS="quote">del sol bracket will not fit 99 si compressor.
BOTTOM LINE.
if you have a 92-00 civic. use a 94-97 p54 del sol vtec bracket, and retain your WHOLE stock sohc a/c system. don't even bother to unbolt anything, or evacuate the system. </TD></TR></TABLE>
well when i bought the car, the guy who had it before took the a/c off. i can get a complete 00si a/c system and a complete 92-95 civic a/c system. i am wondering if i can use the 00si compressor with the 92 lines
Old Jul 15, 2004 | 08:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterdriver &raquo;</TD></TR><TR><TD CLASS="quote">i am wondering if i can use the 00si compressor with the 92 lines </TD></TR></TABLE>
Not going to work... The 92 Civic lines will work ONLY with the 92-95 Civic/Del Sol compressor and condenser.
Old Jul 15, 2004 | 08:18 PM
Madspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">You need to use a Del Sol VTEC (B16A3) A/C bracket and the stock D series A/C compressor, lines, condensor, etc.</TD></TR></TABLE>
what does the bracket cost new from HONDA anybody know?
Old Jul 16, 2004 | 05:05 AM
Smooth_Imports's Avatar
Default Re: A/C Bracket... (Madspeed)
http://www.hondaautomotivepart...81%29
106.63
Old Jul 16, 2004 | 10:34 AM
92b16vx's Avatar
Default Re: A/C Bracket... (Smooth_Imports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smooth_Imports &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.hondaautomotivepart...81%29
106.63</TD></TR></TABLE>
Yip, but, you need the tensioner pulley, pulley bracket, nuts and bolts for said pulley and bracket. I just ordered everything from there and it was just over $200 for everything.
Old Jul 16, 2004 | 11:23 PM
Default Re: A/C Bracket... (92b16vx)
you can use all the parts from your existing bracket (gsr/ls/b16a) etc.
Old Jul 17, 2004 | 03:13 AM
92b16vx's Avatar
Default Re: A/C Bracket... (TECH43 RACING INC.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. &raquo;</TD></TR><TR><TD CLASS="quote">you can use all the parts from your existing bracket (gsr/ls/b16a) etc.</TD></TR></TABLE>
I didn't have any of the parts, whn I got the motor is came with a bare mount.
Old Jul 23, 2004 | 10:36 AM
ef ect's Avatar
used a crv bracket on mine p7j off a 97 crv. this was in a 97 hatch should work the same in any 92-00 civic using civic conpressor.
redsled00
Oct 14, 2005 06:39 PM
95excoupe
Jun 29, 2005 12:52 PM
civic_speed99
Mar 18, 2005 11:43 AM
94HybridEX
May 13, 2002 12:37 AM
CivicEx95
Apr 25, 2002 01:04 PM
