Couple b20/vtec questions I need answered.
I just bought my b20z swap today and I had a bunch of questions that I need answered. Here will be the setup I have so far:
B20Z2 complete engine swap
GSR complete head with LS/Vtec dowels already installed.
00 Si transmission
I need to know which parts from the b20 motor I will be able to put towards the swap (like harness, mounts, sensors, ect.)
Also, which headgasket do I need and where can I find one? Which belts do I need to use also?
Any help with the questions would be greatly appreciated.
00 Si transmission
Re: Couple b20/vtec questions I need answered. (Hatchbizzack)
you bought a swap w/out researching this?
try http://www.huanderson.com/crvtec.html <- do research.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchbizzack »</TD></TR><TR><TD CLASS="quote">I
Also, which headgasket do I need and where can I find one? Which belts do I need to use also?</TD></TR></TABLE>
You will need to use the B20 head gasket because of the larger bore size. This may also help you with some of the other questions: B20/VTEC build
Re: Couple b20/vtec questions I need answered. (andera)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andera »</TD></TR><TR><TD CLASS="quote">you bought a swap w/out researching this?
try http://www.huanderson.com/crvtec.html <- do research.</TD></TR></TABLE>
~ everyone is entitled to be taught once, as long as they listen and learn ~
