JDM B18C into 95 LS...HOW TO?
Old 07-16-2004, 06:55 AM
spark plugs.
Guest
Posts: n/a
Default JDM B18C into 95 LS...HOW TO?
https://honda-tech.com/zerothread?id=928005
anyone in here can help me out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Hey fellahs,
I have a 1995 Integra LS. I want to do a complete GSR swap into it ( https://passwordjdm.com/index....swaps ) probably using that swap. Yes, I've searched but I haven't found anything useful.
I want to know:
What is needed to do this swap?
What wiring changes/mods will need to be made?
Will the LS tranny work on a GSR block?
Will an LS header work on a GSR block?
Are the Intake Manifolds positioned the same or will i need a new intake?
Anything I should know?
Thanks In Advance fellahs!
Old 07-16-2004, 09:31 AM
smart monkey's Avatar
Default Re: JDM B18C into 95 LS...HOW TO? (spark plugs.)
you will need to add wires for vtec,vtop,knock and IAB. if not get the hasport subharness that has all the plugs and pins and instructions. you can't use the jdm engine harness so reuse the stock ls one. the stock ls header will fit but if you can use the jdm one and mod the exhaust. if you don't use the stock jdm man let me know I would take it off your hands. you can use the ls trans but the gsr is better,
Hybridguitarist
10-22-2016 06:55 AM
freebyrd
04-26-2014 09:45 AM
hAtChBaCkFoReVeR
03-31-2010 01:59 PM
sibanez
06-04-2007 11:25 AM
spark plugs.
07-17-2004 12:39 PM
Quick Reply: JDM B18C into 95 LS...HOW TO?
