What harness can i use for a GSR shell?
Im pretty sure im going to be getting a 1994 GSR sedan shell... I have a h22a (obd1) from my accord that i want to put in it. The GSR doesnt come with a harness so im going to need to get one to wire up for the swap. I want to know if i can only use a GSR harness or if a civic of the same years (obd1) or what other harness would work?
Thanks,
Randy
Thanks,
Randy
Re: What harness can i use for a GSR shell? (accord387)
any obd-I harness will do. you might want to get one with vtec plugs so that it'll be easier to install the engine
Re: What harness can i use for a GSR shell? (93H22ACX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22ACX »</TD></TR><TR><TD CLASS="quote">any obd-I harness will do. you might want to get one with vtec plugs so that it'll be easier to install the engine</TD></TR></TABLE>
any obd1 harness... as in even an accord? or any civic or integra obd1 harness... if i could use any obd1 then i could just use the harness from putting the h22 in my accord?
If you are asking about the cabin harness, I disagree with the other replies. IMO you should use a 94 or 95 GSR cabin harness and save yourself a lot of work.
no engine harness... the shell im getting had the gsr swap sold so it doesnt have an engine harness anymore. somone told me i cant use the engine harness i used in my 94 accord in the 94 integra. can i use the accord one or do i need a obd1 civic or integra engine harness
Re: What harness can i use for a GSR shell? (keithg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithg »</TD></TR><TR><TD CLASS="quote">If you are asking about the cabin harness, I disagree with the other replies. IMO you should use a 94 or 95 GSR cabin harness and save yourself a lot of work. </TD></TR></TABLE>
if its not accessible than he can use any OBD-I harness. Its just running a few wires.
why doesn't nayone use the accord harness then, the risistor box is already ran, and all the wires and stuff line up pretty much. When i put the h22 in my accord the harness only took about 2 hours, and that included taking off all of the wire loom and tape and then retapign it all afterwords.
