Which Throttle Cable?
Old Jul 11, 2004 | 08:39 PM
zm_dawg's Avatar
Default Which Throttle Cable?
What throttle cable should I use in my 2000 hatch with JDM GSR swap......this thing is way long and believe it's affecting acceleration......
Old Jul 11, 2004 | 09:05 PM
Newman's Avatar
New User
Default Re: Which Throttle Cable? (zm_dawg)
If you're using the GSR intake manifold and throttle body, you can reuse your Civic throttle cable by moving the bracket in a way that it'll allow the mounting point further out from the throttle body.
Old Jul 11, 2004 | 11:12 PM
zm_dawg's Avatar
which cable can I purchase to get rid of all this slack....right now I have it ghetto rigged and at certain points i'm not even accerlerating cause it doesn't pull tight......?...SI throttle cable?
Old Jul 12, 2004 | 09:39 AM
deSigi's Avatar
Default Re: (zm_dawg)
I cut and crimped part of my cable at the pedal side of the cable to shorten it. Works great, no slack whatsoever. Otherwise a GSR cable would be needed.
Old Jul 12, 2004 | 09:53 AM
halfabrotha's Avatar
I did what this guy did and it works great.
http://repo.jackmoves.com/albun45?page=4
But to answer your question, (if I remember correctly) the GSR cable is the one that fits perfect.
try https://honda-tech.com/zerosearch
IgnitionZ055
Apr 7, 2008 02:22 PM
SpoonEk253
May 27, 2006 06:20 PM
