Trouble hooking up knock sensor ans iab
I have a 93 si hatch and i can't seem to hook up the knock sensor. For the iab i moved a17 to a20, now what? Thanks
I hope you meant A20 to A17 because the way you said it wont run the IAB...Knock sensor...are you looking for the sensor itself or do you need a plug?? The sensor is on the block, near the alternator side...It is a round plug I believe...The ECU pin is D3 I believe too...
