HELP!!!! B20 BRACKET MOUNT QUESTION
Old Jul 20, 2004 | 08:13 AM
brizjuan's Avatar
Default HELP!!!! B20 BRACKET MOUNT QUESTION
IM PUTTING A B20B IN TO A 95 DEL SOL SI... THERES A BRACKET ON THE TIMING BELT SIDE OF THE MOTOR THAT MOUNTS TO THE HEAD ITSELF WITH 3 BOLTS IN AN UPSIDE DOWN TRIANGLE PATTERN. IM USING ALL INTEGRA GSR MOUNTS SO THE BRACKET WILL NOT WORK BECAUSE THE 2 STUDS THAT THE MOUNT SLIDES OVER WONT LINE UP. I WAS TOLD TO USE A 2000 CIVIC SI BRACKET BUT INSTEAD OF 3 BOLTS THE CIVIC SI BRACKET MOUNT UP WITH 2 BOLTS IN A VERTICAL PATTERN.... SO WHAT CAR DO I NEED A BRACKET FROM IN ORDER TO MAKE THIS WORK... I ALREADY ORDERED THE BRACKET FOR THE 2000 SI FROM HONDA... PLEASE RESPOND ASAP....
Old Jul 20, 2004 | 03:22 PM
smart monkey's Avatar
Default Re: HELP!!!! B20 BRACKET MOUNT QUESTION (brizjuan)
you need a 94-teg mount bracket. I have one for sale for 40.00 shipped.
miamihonda
Mar 27, 2021 05:10 AM
Daniel99
Jul 12, 2018 09:17 PM
flanker
Dec 8, 2014 01:26 AM
1990crxsir
May 29, 2006 04:43 PM
EKRacer
Mar 24, 2004 07:02 AM
