EG/H22 HASPORT .... HELP...
How do u put the right passenger mount in if you're droping it from the top... also, do u have to drill holes....
Re: EG/H22 HASPORT .... HELP... (yangja)
Drilling? Are you talking about the removal of the passenger side stock mount? You need to drill the spot welds out to remove the mount. I put my engine in from the bottom of the car. But I think you are going to have to angle the motor in to be able to put the passenger side mount in from the top. Drop the tranny side down lower get your then the cam sprocket side. Get your mount positioned then level out the motor. I tried dropping the H22 from the top for all of 5 minutes before I decided it looked easier to put it in from the bottom of the car.
Re: EG/H22 HASPORT .... HELP... (double)
actually i was taking about the Hasport passenger right side mount... do i have to drill hole for that to go in???
