97 d16y7 harness onto 01 b18c1
Old 07-10-2004, 02:30 PM
Prod's Avatar
Default 97 d16y7 harness onto 01 b18c1
from all the reading I've done I thought I had it all figured out, extend a few wires...add vtec, IAB, do the iacv+ckp fix and I'm good, should be plug and play otherwise.
well I went to swap the harness today and I'm not so sure I trust what I've read. Thus far, the IAT, evap and IACV sensor plugs aren't even the same type of plug (I stopped here b/c I'm pissed off now) Do I really need to swap plugs on some of the sensors or am I doing something wrong here ? I haven't read anything that even mentioned this...
Old 07-11-2004, 05:40 AM
97civicdx's Avatar
Default Re: 97 d16y7 harness onto 01 b18c1 (Prod)
Yes, you are supposed to change plugs to the teg motor if the oe ones dont plug in. Remember, you are putting a different motor into a car it wasnt supposed to go in.
Old 07-11-2004, 09:35 AM
Prod's Avatar
Default Re: 97 d16y7 harness onto 01 b18c1 (97civicdx)
alright I just found it odd that I found no mention of that
Alex V
07-05-2019 10:46 AM
SinsEvil666
02-19-2009 01:16 PM
GReddy SI
02-04-2003 10:26 AM
Quick Reply: 97 d16y7 harness onto 01 b18c1
