Hole in tranny - add ins (trans, transmission)
Was changing my oil the other day and noticed this hole in the bottom of my transmission...
picture of the hole
close up of the hole..
What could of caused this? Is it still ok to use this tranny?
picture of the hole
Re: Hole in tranny - add ins (j boy)
yeah you can use it, looks like something hit your clutch housing, a rock maybe? may get a little dirty and dusty inside.
Re: Hole in tranny - add ins (torr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torr »</TD></TR><TR><TD CLASS="quote">I wish I can install hondata on my girlfriend so I can tune her mouth shut..</TD></TR></TABLE>
lmfao
lmfao
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torr »</TD></TR><TR><TD CLASS="quote">yeah you can use it, looks like something hit your clutch housing, a rock maybe? may get a little dirty and dusty inside.</TD></TR></TABLE>
So you dont think anything is wrong inside of my tranny?
If i were you i would get that fixed as soon as possible because dirt and oil may enter the bell housing and get on the clutch, which will cause your clutch to start slipping and wear faster than normal. Aslo that crack will cause your transmission housing to be that much more weaker. Sooner you get it fixed the less you'll suffer in the long run.
Re: (j boy)
It was most likely from bottoming out on a big rock or something similar.It will be ok though.Though it would be best to get it welded up or at least jb weld something on it to cover it up,its not 100% necessary.Ive run thousand's of miles without the flywheel shield on many of my cars and have had no problems..it just helps prevent any large objects from entering the bell housing and possibly causing something to happen.Like I said though,ive never had a problem,but that doesnt mean you wont.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMotive »</TD></TR><TR><TD CLASS="quote">It was most likely from bottoming out on a big rock or something similar.It will be ok though.Though it would be best to get it welded up or at least jb weld something on it to cover it up,its not 100% necessary.Ive run thousand's of miles without the flywheel shield on many of my cars and have had no problems..it just helps prevent any large objects from entering the bell housing and possibly causing something to happen.Like I said though,ive never had a problem,but that doesnt mean you wont.</TD></TR></TABLE>
cool, thanks for the heads up.
anybody with other suggestions feel free to post.
Re: Hole in tranny - add ins (1.6i-16zc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i-16zc »</TD></TR><TR><TD CLASS="quote">jb weld?</TD></TR></TABLE>
Yep
Yep
Re: Hole in tranny - add ins (HATCHingMN)
RhombeusGSR
06-28-2004 12:02 PM
