99-00 SI harness question
Old Aug 7, 2004 | 12:46 PM
shadykit's Avatar
Default 99-00 SI harness question
My friend is doing a 99 GSR swap with 99 GSR ecu, can we use a 99-00 Civic SI wire harness? I know that it's better to use a 96-98 Civic Ex harness cuz they're both obd2a.
Old Aug 7, 2004 | 01:02 PM
shadykit's Avatar
Default Re: 99-00 SI harness question (kitchale)
If not can I use a 96-98 civic ex automatic harness, if so all i need to do is
change the IAC right?
Old Aug 7, 2004 | 04:36 PM
locash's Avatar
It all depends on what car it is going into. If you are putting the GSR motor into a 99-2000 Civic DX/EX/LX/CX/Si, you should use the 99-00 Si harness, add the iab, change the IAT wiring, and then use an ecu adapter to run the 99 GSR ecu.
If the car is a 96-98 Civic DX/EX/LX/CX, use the 96-98 Civic EX harness, add the IAB, change the CKF, IAT, IACV, and distributor wiring, and you should be good to go.
I may have forgotten a few minor details, but you get the point. Do not try to use a 99-00 Si harness in a 96-98 Civic, or vice versa. The 99+ has one of the ecu plugs in the body harness, whereas the 96-98 have them all in the engine harness.
hmtcrxsir
Apr 27, 2019 08:09 AM
94eh2
Nov 2, 2009 09:51 PM
blaacksheep
Mar 9, 2005 10:44 AM
hatchattak
Sep 7, 2003 06:41 AM
dry-ice
Mar 13, 2003 06:07 PM
