Maybe Overheating?
Old Aug 15, 2004 | 12:22 AM
Crank's Avatar
Default Maybe Overheating?
Hey all, I have a slight problem with my 93' Si stock except for exhaust , The cluster says I am overheating but the car isnt. Anyway I can fix this problem? I just recently replaced the radiator and fan belt and I thought that might just fix the problem. I really need help guys, I am starting to get scared driving this car.
Old Aug 15, 2004 | 01:42 AM
Crank's Avatar
Default Re: Maybe Overheating? (Crank)
bump it up
Old Aug 15, 2004 | 07:54 AM
Crank's Avatar
TTT!
Old Aug 15, 2004 | 01:23 PM
Crank's Avatar
bump again..
Old Aug 15, 2004 | 03:39 PM
Kamin's Avatar
how do you know you arent overheating?
is the gauge pegged at full hot?
Old Aug 17, 2004 | 01:05 PM
Crank's Avatar
Default Re: Maybe Overheating? (Kamin)
sorry guys comp was broken, the car temp raises too fast for a cold start, when i drive normal, the temp gauge reads hot when i aint even overheating. if anyone can help me out with this problem, it would be great.
Old Aug 17, 2004 | 01:16 PM
Kamin's Avatar
sounds like the thermostat is stuck closed, remove it and see if it fixes the problem. if it operates better, buy a new thermostat.
Old Aug 18, 2004 | 11:02 AM
sullenht's Avatar
it could be the temp switch itself
Old Aug 18, 2004 | 06:47 PM
xpwex's Avatar
Default Re: Maybe Overheating? (sullenht)
check the top hose that goes to the radiator and compare it to the bottome one if the temp is different then change the thermo also is you fan coming on all the time or is it coming up at all if not it just the temp bulb other word a sensor in the back by the dizzy change it out ......
instructor74
Nov 20, 2008 06:29 PM
meanshyguy
Aug 24, 2008 07:50 AM
CrisEK
Sep 30, 2005 04:27 PM
ButterMule
Nov 27, 2004 10:19 AM
