Driver side torque mount. which one?
Old Aug 15, 2004 | 03:49 PM
aZnjCC's Avatar
Default Driver side torque mount. which one?
Okay, my driver side torque mount rubber is cracked. Its the one that you can see in driver side wheel well. I have a b18c jdm gsr motor in a 97 civic hx cvt. I had a shop do the swap, and they didn't realize it was cracked until i picked it up. My question is, is that mount from my d-series, or the b18c? If I were to replace it, which motor would i get it for? And what is involved with the process of removing it and replacing it?
Old Aug 15, 2004 | 05:13 PM
smart monkey's Avatar
Default Re: Driver side torque mount. which one? (aZnjCC)
I believe use a civic mount as the teg is flat at the base and the civic is not to fit the hump on the chassis
Old Aug 15, 2004 | 05:21 PM
aZnjCC's Avatar
is this an easy diy?
Old Aug 16, 2004 | 08:27 AM
aZnjCC's Avatar
also, just to clarify, when i'm rollin in first at a really slow speed, and i disengage the clutch, the motor seems to shake and shudder.
This also happens when i'm in gear and revving it up high above 6000 ish. When i clutch in, the whole motor seems to move. This is caused by the motor torque mount i am referring to right?
Old Aug 16, 2004 | 12:09 PM
Default Re: (aZnjCC)
to answer both it is a easy diy but also as for the shuttering it is hard for me to say unless I saw the car or rode in it.
Old Aug 20, 2004 | 11:30 AM
aZnjCC's Avatar
****. which mounts do i need.
My car was a 1997 Civic HX CVT automatic transmission, but now with a jdm gsr motor/tranny.
Do i get the torque mounts for the cvt auto, or the manual? they are different part numbers
kaiba
Northern California (Sales)
Jun 9, 2013 12:42 AM
thedon360
Mar 3, 2013 03:16 PM
94integragsr
Jul 13, 2005 07:21 PM
aZnjCC
Aug 22, 2004 12:20 AM
RacerSi
Dec 30, 2003 03:03 PM
