b18c5 motor question .. .. ..
Old Aug 10, 2004 | 07:17 PM
makaveli284's Avatar
Default b18c5 motor question .. .. ..
Hey whats going on guys? I am in the process of doing research for my b18c5 swap and was wondering which version i should try to get . .the USDM or the JDM . . 10:6 comp ratio or 11:1 . . . which one is easier to modify / tune . . any help would b VERY much appreciated . . sorry if i sound stupid lol . .thanks . .good day / nite . .
Old Aug 10, 2004 | 07:39 PM
Kapman38's Avatar
Default Re: b18c5 motor question .. .. .. (makaveli284)
Get the JDM if you can afford it; higher comp will help; especially if you are going all motor...USDM heads are the same as JDM, so if you can get a good deal on a JDM shortblock, and then find a deal on a USDM head, you are set...add cams etc...
just my $.02 worth...
Old Aug 10, 2004 | 07:46 PM
520_Motorsports's Avatar
Default Re: b18c5 motor question .. .. .. (Kapman38)
Go jdm I would if I could afford it. Better compression ratio, less miles on it than you would probably in the good ole US of A and probably cheaper anyways junkyards are super expensive( at least where I live).
92SiBlu
17
Dec 15, 2004 08:23 AM
auburnBoy
May 27, 2004 06:38 PM
l3loodred
Sep 3, 2003 12:29 AM
RuffGsR
Jun 27, 2003 12:25 PM
Irishweird00
16
Feb 7, 2003 09:01 PM
