how 2 disconnect shift linkage 99 ls
Im workin on pullin my motor. I've got one linkage rod out that was held by a bolt, but the other one has a riveted pin type thing in it. Whats the best way to disconnect this? I could disconnect it under the shifter box but I would rather at the tranny.
Thanks in advance.
Thanks in advance.
Re: how 2 disconnect shift linkage 99 ls (jdmjizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjizzle »</TD></TR><TR><TD CLASS="quote">Im workin on pullin my motor. I've got one linkage rod out that was held by a bolt, but the other one has a riveted pin type thing in it. Whats the best way to disconnect this? I could disconnect it under the shifter box but I would rather at the tranny.
Thanks in advance.</TD></TR></TABLE>
It sounds like you've already removed the spring pin clip. Now you just need a 8mm pin punch and tap the spring pin (aka bitch pin) out from the bottom using the pin punch and a hammer.
You can also use a 5/16th" pin punch, or I've read that the long 8mm bolt that bolts the AC compressor to the AC bracket works too. If you cant find a pin punch use that bolt from your AC system.
mstewar
03-03-2006 12:23 PM
Black_SiR
10-26-2004 03:24 PM
