problems with the egr lift sensor
Old Aug 6, 2004 | 09:43 AM
sIcWiTiT's Avatar
Default problems with the egr lift sensor
yeah i am having some problems figuring out which pin on the sensor goes where. i am posting a pic of the sensor. i know its blurry but its the best i could do. if someone could tell me from left to right on the sensor where each pin goes.
thanks
Old Aug 6, 2004 | 09:45 AM
sIcWiTiT's Avatar
Default Re: problems with the egr lift sensor (flosSIn)
by the way its a h22 swap done on a 92 cx
Old Aug 6, 2004 | 10:58 AM
93H22ACX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">EGR (Exhaust Gas Recirculation) System: Applies to all model civics except VX using the VX engine harness. If you do not use the VX engine harness in a VX, then you need to do this!
- EGR lift valve solenoid - sensor voltage (A25 pinout) & ECU signal to A11
- EGR lift sensor - sensor voltage (A25 pinout), ground (D22 pinout) & ECU sensor signal to D12
Old Aug 6, 2004 | 11:03 AM
Turbogixxer's Avatar
Default Re: problems with the egr lift sensor (93H22ACX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">EGR Wiring Info
USDM wire colors are the same as JDM.
Connector colors means that when looking at the connector (wire pointing towards you) that the way they should line up (From left to right)
(The connector colors, From left to right) BLK/YEL and RED
Sensor Voltage - BLK/YEL - goes to A25
ECU trigger - RED - goes to A11.
EGR Lift Sensor (the actual EGR on the intake manifold)
(The connector colors, From left to right) WHT/BLK, GRN/WHT, and RED/WHT
ECU trigger - WHT/BLK - goes to D12
Sensor ground - GRN/WHT - goes to D22
Sensor voltage - RED/WHT - goes to D19 or A25
Old Aug 6, 2004 | 11:12 AM
93H22ACX's Avatar
Default Re: problems with the egr lift sensor (turbogixxer)
Looking at the sensor....
WHT/BLK - to D12............Left
GRN/WHT - to D22..........Middle
RED/WHT - to D19 or A25........Right
theharlequin
10
Jun 27, 2006 09:56 AM
INTEGRA SIR
Mar 1, 2006 07:15 AM
Civic VX
Nov 22, 2004 10:24 AM
mattEG
Aug 24, 2004 04:16 PM
G3gsr
Apr 27, 2003 11:07 AM
