h22a ecu problem
Old Aug 17, 2004 | 03:55 PM
type-t's Avatar
Default h22a ecu problem
i'm doing an h22 swap into a 92' accord coupe...i know im supposed to add the following wires to the P13 ecu:
-IAB control soleniod...into pin# A17 (Consist of two wires)
-Knock sensor into pin# D3 ( one wire)
-V-Tec pressure switch into pin#D6 ( two wires)
-V-Tec valve into pin# A4 (one wire)
each one of these is assigned to one pin even if they have two wires...for example..the IAB control & the V-Tec pressure switch...which wire do i pug in to where?
im not worried about the knock sensor or the v-tec valve...only one wires comes out?.....please help soon
thanks
Old Aug 17, 2004 | 04:20 PM
Mark 2121's Avatar
Default Re: h22a ecu problem (type-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-t &raquo;</TD></TR><TR><TD CLASS="quote">-IAB control soleniod...into pin# A17 (Consist of two wires)
If you use the IAB connector from the old harness (jdm or usdm) Pink goes to A17 and blk/yel is sensor voltage. Sensor voltage can tapped into any yel/blk wire or A25 or B1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-t &raquo;</TD></TR><TR><TD CLASS="quote">-Knock sensor into pin# D3 ( one wire)</TD></TR></TABLE>
This is a sheilded wire. That means it has a mesh wire on the outside of the wire. You need this type of wire. You can take it off your old harness (h22a).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-t &raquo;</TD></TR><TR><TD CLASS="quote">-V-Tec pressure switch into pin#D6 ( two wires)</TD></TR></TABLE>
One wire goes to D6, the other is a ground. Ground it anywhere (good connection).
Others, just ran to the ECU like normal.
Old Aug 19, 2004 | 06:39 PM
type-t's Avatar
Default Re: h22a ecu problem (ek2121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek2121 &raquo;</TD></TR><TR><TD CLASS="quote">
Others, just ran to the ECU like normal. </TD></TR></TABLE>
ok i c..now i used regular unshielded wire for the knock sensor..its this going to affect anything..and yes i did notice that the knock sensor wire had a mesh around it...what it the purpose of this?
C_I_V_I_C_V_T_E_C
Sep 15, 2007 04:28 PM
Project92Hatch
Mar 26, 2003 01:22 PM
topspeed02
Feb 19, 2003 05:53 AM
takeheed
Sep 3, 2002 12:30 PM
