SIR-G Swap
Re: SIR-G Swap (98JDM_Type_R)
Okay, I already got the driver side mount & rear tranny mount. Do I need to change the wire harness? I'm going to be using a OBD1 P72 ECU.
You'll need to get an OBD2B to OBD1 ECU adapter harness to use the OBD1 P72 and then add the necessary wiring for the added sesors. If you can get a 99-00 Si harness it will be more plug and play but any other 99-00 EK harness will work with only a few changes and added wires.
might find some additional info in here: https://honda-tech.com/zerothread?id=650230
Re: SIR-G Swap (89cr-ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89cr-ls »</TD></TR><TR><TD CLASS="quote">might find some additional info in here: https://honda-tech.com/zerothread?id=650230</TD></TR></TABLE>
I've already read those posts, but they only cover obd2 to obd2 swaps. They don't talk about obd2 to obd1 swaps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98JDM_Type_R »</TD></TR><TR><TD CLASS="quote">
I've already read those posts, but they only cover obd2 to obd2 swaps. They don't talk about obd2 to obd1 swaps.</TD></TR></TABLE>
, i didn't really read all of them...just figured they might have some useful info. well try searching and maybe: http://tech.hybridgarage.com/
