H Series Swappers... (eg,delsol)
im having some problems with my throttle cable i think. or possibly the spring on the tb. has anyone else had issues with this? ive read the writeups for the swap and everyone says you can use the d series throttle cable and just flip that holder around. if i replace the throttle cable. which one should i get? d,b, or h? (b just cause i heard there shorter....)
(oh yeah and does it matter which model? d16y8 or d16z6, h23a or h22a?)
Re: (rtpassini)
Mine would idle high after gapping on it, i adjusted it but it didnt help, then a few days later it went away on its own...?? lol hopefully yours will too! I was using the civic cable w/ the flipped bracket.
Re: (rtpassini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtpassini »</TD></TR><TR><TD CLASS="quote">my idle often stays up at 1500-2000 and after driving it hard. itll usually just drop down and clunk out.</TD></TR></TABLE>
Hmm, that doesnt sound like a cable problem. If your cable were too short the idle would stay higher regardless of how hard you ran it.
Re: (rtpassini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtpassini »</TD></TR><TR><TD CLASS="quote">sometimes itll even stay at like 4 grand after driving hard.</TD></TR></TABLE>
Hmm........ well, if it is indeed sticking open after hard driving i would just try some carb cleaner on your tb; clean it up might just be gunked up. Are you using your stock d series cable right now? I dont see it being the cable though, not if you're saying the problem only happens after hard driving.
Re: (AudioFuct)
Sounds like you might have an issue hooking up the D series throttle cable. It will work with your swap.
But, the 98 + Prelude throttle cable will work also. Don't expect it to solve the problem unless you know what the issue is.
alx_90ef
10-14-2010 04:45 PM
