B16a VS GSR Tranny
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
I have a b16a, bolt ons.
I have a b16a gearbox, i want to switch to a gsr tranny.
How much slower would i be if any difference at all, due to the gsr taller ratios.
I recently went from a gsr tranny to a Type R trans (B16a ratios) and its faster for sure but Im wanting to put the gsr back in
Id go GSR But im also running A turbo GSR motor 262whp.... It seems with the type r trans im shifting into 5th alot... the gsr 4th is pretty solid gear
I like to party
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast83 »</TD></TR><TR><TD CLASS="quote">
How much slower would i be if any difference at all, due to the gsr taller ratios.</TD></TR></TABLE>
As long as you don't fall out of VTEC when you shift it really won't make a huge difference. Obviously higher gears are faster (barring shift points, track length, traction, etc) but going from the b16 to the gsr won't change much other than your gas milage.
![](https://honda-tech.com/forums/images/smilies/emwink.gif)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2LEM1 »</TD></TR><TR><TD CLASS="quote">
He will fall out of vtec, in my opinion it's a horrible idea. A tourqeless B16 and adding taller gears is not a good combination.
Just a side note to the OP I picked up 3 tenths in the 1/8 by switching out my GSR granny for a B16.
AzN_Flava
04-11-2003 06:57 PM
