head gurus need help if possible h22 head
Is this port screwed up someone they they were a head porter and i not sure if it is ruined or no. pics might not be good to see but and comments are welcome. looks like they were just trying to port match the gaket
that is the one they tryed to do there own work on
that is stock neverbeen touched
like i said not sure is anyone can help but trying to figure out if it is worth keeping or throw it out.
Re: head gurus need help if possible h22 head (k24killer)
as long as it was a regular casting clean up and basic blend nothing should be wrong...soeme people like water jackets more than others
flow the head and see what happens in each port...then get back to this thread
Re: head gurus need help if possible h22 head (dschenke)
definitely like the other guys said those pics are terrible cant tell anything post it with high resolution
Re: head gurus need help if possible h22 head (teefunk01)
the pics are not the greatest but you can definitely tell there was an abrasive flap wheel used on the one port entry...flow bench the head and see what numbers you get from all 4 cylinders that will tell you what you can use and what you can make a table out of...re post the numbers on here and then decide for yourself
