2.25" Exhaust on B16 with Tuner 3's
Old 06-26-2011, 02:54 AM
7rrivera7's Avatar
Default 2.25" Exhaust on B16 with Tuner 3's
Bought a Del Sol with a rebuilt but stock B16 which supposedly has S2 Tuner 3's installed on a semi-built head. She pulls hard after VTEC up to 9k - more than I'm used to "feeling" so they might be T3's afterall but I'm not planning on pulling the cams to find out.
Anyway, the car's exhaust (header, straight thru to Magnaflow muffler) is too loud so I was planning on throwing in a resonator and noticed the tubing is 2.25" which may or may not be too restrictive?
Since I was thinking of "eventually" modding the engine for AM, I thought of installing a 2.5" mandrel kit from VRS along with a high-flow resonator and a Vibrant muffler. Or should I just throw on a regular no name $20 2.25" resonator (not high flow of course) for now to get rid of the loud tone?
Old 06-26-2011, 05:53 AM
todahead's Avatar
Default Re: 2.25" Exhaust on B16 with Tuner 3's
go 3'' it will be ok if you use big resonators.
Old 06-27-2011, 02:29 AM
7rrivera7's Avatar
Dude, it's an all-motor B16!
Old 06-27-2011, 03:25 AM
Coler's Avatar
with stage 3 cams go for a 2,5"
Old 06-27-2011, 05:51 AM
mar778c's Avatar
Lol, I guess B16's can't benefit from reductions in back pressure.
Old 06-27-2011, 10:17 AM
kyosoeg6's Avatar
all you have to do is pull off your distributor to see any markings on the intake cam.
Old 06-27-2011, 11:21 AM
DDTECH's Avatar
3''. Its been proven and its been well discussed. The less backpressure the better.
You're allowing the motor to breath easier, it'll make the power.
Old 06-27-2011, 02:14 PM
OMG
OMG's Avatar
Can a car lose HP from going from exhaust to straight header (infinite, way bigger than 3")?
Old 06-28-2011, 09:11 AM
todahead's Avatar
obviously no
Old 06-28-2011, 09:19 AM
7rrivera7's Avatar
wow, all along I thought going too big would kill torque and horsepower but if ALLMOTOR says 3", I can't argue based on his rep...
Old 06-28-2011, 09:43 AM
OMG
OMG's Avatar
What about putting a device at the end of the header that gradually slows down the exhaust to avoid turbulent flow and also create a reflective negative back-pressure wave to create a tuned cancellation of exhaust-valve reversion? That might be better than a straight transition into said "proven" Monster 3" exhaust.
Old 06-28-2011, 10:37 AM
DDTECH's Avatar
Everything after the final merge collector is either for emissions or evacuation, and is a restriction.
Just trying to help, search, its been discussed and debated until people are blue in the face. The noise is about the only draw back to running a bigger pipe diameter. Could careless about "street" credit.
Old 06-28-2011, 10:51 AM
STAR
BMo Tuning's Avatar
Stuff some fiberglass(or maybe some argyl socks) in your exhaust.
Restriction = power
Old 06-28-2011, 11:05 AM
OMG
OMG's Avatar
Taken to its logical conclusion, no header works best.
Old 06-28-2011, 11:07 AM
vmshaw2's Avatar
Go for a 2.5,
Old 06-28-2011, 12:29 PM
flavio's Avatar
in my case i'm runing a stock b16 block stock head, itr cams, itr intake mani/TB w/ cai chiped ecu and 2' ex.. stock ex header
but i have a 2.75 ex here at home..
2.75 will make more power than 2'?
Old 06-28-2011, 12:56 PM
DDTECH's Avatar
Always.
Old 06-28-2011, 12:59 PM
flavio's Avatar
next week i do the feedback :D
Old 06-28-2011, 03:49 PM
mar778c's Avatar
That logic works only if the laws of physics have been suspended.
Old 08-22-2011, 06:59 AM
mhax's Avatar
People that think back pressure is a myth are missing some understanding of the physic behind fluid dynamics...Some people will also tell you that the second butterflies in the gsr intake manifold is bad because it is restrictive! The word restrictive is probably the only word they can understand! The intake problem is quite a simplier problem, but still some people won't understand it. The exhaust air flow is alot more complex since the fluid dynamic behind it is completely different.
Some people really think that engineers working for bmw and other car company are stupid and that they put dual butterflies intake and variable exhaust muffler just because they want the engine to make less power...sigh...Anyway i could continue this text forever, but that would probably be useless!
Old 08-22-2011, 07:10 AM
Ridewithme38's Avatar
What about Exhaust scavenging? Don't pipes that are too large cause the exhaust to slow down and actually screw up flow?
Old 08-22-2011, 08:37 AM
mhax's Avatar
It's all about volume! Some race car model will use a variable exhaust which will modify the back pressure in order to keep the volume optimized with the rpm. Since we don't have such a system in old honda/integra, going to a high volume exhaust piping will kill the back pressure at low rpm (because the volume won't be enough to flow efficiently), resulting in a loss of power and torque (edit: at low rpm). The opposite is also true, going to a low volume exhaust piping will kill the flow at high rpm, because the volume will be restricted. The best exhaust to have also depends on if it is going to be used on the road or on the track. If the exhaust rarely see low rpm/low volume because it is only used on the track, then a high piping size can be used. If the exhaust rarely see high rpm/high volume because it is a road car, then a standard piping size should be used. Since i usualy drive my car on the track and on the road, i would prefer something in between.
Old 08-22-2011, 08:39 AM
7rrivera7's Avatar
Got some good people on here commenting. Thanks for all the feedback!
b16ej6
28
08-30-2010 11:27 AM
SlammedEG6
10
03-23-2010 08:24 AM
flyingduck04
06-02-2005 08:29 AM
Ricochet.
23
03-27-2005 08:15 PM
Quick Reply: 2.25" Exhaust on B16 with Tuner 3's
