block guard or not?
block guard or not?
Here is my build gsr block and head. No boost planed. All motor. Stock thickness head gasket. skunk2 70mm t-body and intake manifold. Aries forged pistons with a +5 dome. Skunk2 valves, springs, retainers, pro2 cams. ARP head studs. I have a block guard but have been reading that they can cause hot spots on sleeves. Also can rattle? I tried to install the block guard with no luck. Its a very tight fit and I don't want to mess the deck up on the block. I got the block guard just because I was going to have the head off and figured it would be a good idea to get one but now I am not so sure. Looking for some input. Install block guard or forget it?
Re: block guard or not?
block guard will make your motor overheat, means less coolant will go through between the cylinders, thats what happen to one of my friend fully build gsr motor, its similar to your set up, i say dont used it.
So the stock sleeves should be able to handle what I am doing to it. I forgot to that I also have a lower temp t-stat and fan switch installed on the block. If I remember correctly I think the t-stat is a 60 degrees celsius and the fan switch is an 80 degrees celsius.
yea the stock sleeve will be no problems if your not going over 82mm bored, any bigger than that i consider resleeving the block, unless the car is only drag only car not daily driver but still its not a good to have a block guard, with no block guard you can still daily drive the car quiet sometime...
For Sleeves that can easily be distorted(b20 sleeves) its a good thing to use, if funds are tight and you just want alittle extra. Its almost to the same point as to why people run girdles. You dont really need it, but people want to run one for a peace of mind. If a motor isn't properly balanced for the rpms it will see, a girdle is a good idea for added safety for the bottom end.
All Motor Mentor
1 Post
It's called marketing. Sell what people will buy, not what they need. If there's a buck to be made somewhere, people will make anything and tell you why you need it. I'm oversimplifying the reasoning for the block guard here but it's basically true.
Well I think I am going to ditch the block guard. Like I sayed when I put this post up was that I was going to have the head off. And I was thinking what the hell why not put a block guard in. But now I am not going to. I will have to get pics of the build up here soon.
Purpose Built
No the ls doesn't but they make aftermarket ones
Then it was installed incorrectly or it had another issue.a block guard just doesn't start making your engine overheat
"Fully built" lolz
"Fully built" lolz
Not quite a placebo. I had my B18 a block bored for next size up pistons. The shop recommended a block guard, but I said no. I then provided a deck plate for the honing stage, and after it was in place the cylinder was out of round just enough that I had to go up to the next size piston. The shop does championship level drag cars, so they normally know their stuff - but this surprised them. They really should have waited for the deck plate before doing the bore, but they thought it would be ok.
The pertinent observation is that if just adding a deck plate distorts the cylinder so its a bit out of round, then so will bolting on the head. I authorised instalation and welding in a block guard, and then they rebored and honed it with the deck plate. Price adjusted.
For info, race orientation engine, 11.7 cr pistons before milling etc, likely to end up 12.5 cr when b16 head b18c crank and b18c rod combination and milling added.
I have a D16y7, ebay turbo build, gonna have YCP pistons with the custom long rod no block notch set up. Planning to make around 400hp. Will I be safe without a block guard??
